I have a Stratix IV on a a Terasic TR4 development kit. I'm trying to load an encrypted bitstream on the stratix IV. I'm already able to load an encrypted bitstream using FPP in Quartus II: - program the stratix IV with a Parallel Flash loader - load the pof directly in the flash - program the key .ekp Then at reset, the bitstream is decrypted and programs the Stratix IV. But it has 2 main drawbacks : It's very slow and I want to have a command line solution (preferably with a .rbf file) Would you have a better solution ? Is a direct loading from USB blaster possible ? Do you know the related command line ? Thanks for your helpLink Copied
Hi again :)
I've tried to use the Passive Serial loading using the mblaster tool. This seems to allow the loading of an encrypted bistream. I put the MSEL1 to 1 on the board, the cable is well detected by the software. At the end of the loading (on , the tool says the configuration is loaded successfully but the configuration does not run on the fpga ... any clue ? I have another question: - even if it's very slow, I dit use the PFL loading http://www.altera.com/literature/an/an478.pdf which works I'd like to script it but I'm not able to find how to "attach a flash device" with a pof file in quartus_pgm Where could I find the way to do that ? Thanks- Mark as New
I did read altera documentation and it seems to be possible to load encrypted design in Passive serial mode (AN556).
But I can't find how to do that using my TR4 board ! Is it possible ? Should I use the USB Blaster ? How could I do that ? Thanks
