THERE have some error of my code
but i don't know how to slove this problem
can anyone help me to correct my code
thank you so much !
this is the errror message i had:
Error (10822): HDL error at triangular_carrier.vhd(21): couldn't implement registers for assignments on this clock edge
this is my code:
entity triangular_carrier is
architecture Behavioral of triangular_carrier is
signal x,y:INTEGER:=0;
begin
process(clk,Ts)
begin
case x is
when 0 =>if (clk'event and clk='1') then <---- there is my error occured
if y/=(Ts/2)then carrier <=y+1; y<=y+1;
else x<=1;carrier<=y-1;y<=y-1;
end if;
end if;
when 1 =>if (clk'event and clk='1') then
if y/=0then carrier <=y-1; y<=y-1;
else x<=0;carrier <=y+1; y<=y+1;
end if ;
end if;
when others=>null;
end case;
end process;
end Behavioral;
i revised the code as you teach me
but i have this error message below:
Error (10500): VHDL syntax error at triangular_carrier.vhd(33) near text "process"; expecting "if"
there is the code i revised :
begin
process(clk,Ts)
begin
if(rising_edge (clk) and clk = 1 ) then
case x is
when 0 =>
end if;
when 1 =>
if y/=0 then carrier <=y-1; y<=y-1;
end if ;
when others=>null;
end case;
end process;
end Behavioral;
would you tell me where am i wrong
thank you so much
or can i change the code like this
is this same meaning of my code?
begin
process(clk,Ts)
begin
case x is
when 0 =>if (clk='1') then
end if;
end if;
when 1 =>if (clk='1') then
end if ;
end if;
when others=>null;
end case;
end process;
end Behavioral;
Hello Mark,
i am not sure about above code ..it looks same to my previous one ? ..can I ask what you trying to implement ? If you give me detail info I can try to help you out ?
Thank you ,
Sree
when i foolow your steps then revise my code as you teach
it will have this error message :
And this is the code which i revised
begin
process(clk,Ts)
begin
case x is
when 0 =>
end if;
when 1 =>
end if ;
when others=>null;
end case;
end process;
end Behavioral;
Hello Mark,
Here is the modified code ,
you added the if condition for clk, but didnt add the end if .If it is not confidential ,and let me know what logic you plan to implement i cna help you out if i can ?
begin
process(clk,Ts)
begin
case x is
when 0 =>
if y/=(Ts/2)then
else
x<=1;
carrier<=y-1;
y<=y-1;
end if;
when 1 =>
if y/=0 then
else
x<=0;
carrier <=y+1;
y<=y+1;
end if ;
when others=>null;
end case;
end if; -- Endif here misisng.
end process;
end Behavioral;
Thank you ,
regards,
Sree
