6261 Discussions
Error 16045: Instance "auto_fab_0|alt_sld_fab_0" instantiated undefined entity
JQ2
When I was trying to compile the project with Quartus Prime Pro 20.2, I encountered the following issue during the synthesize stage. This issue appeared suddenly, the same design compiled successfully last week, while not it failed. I searched online and it asked me to contact the Intel. Could somebody help to take a look? Thank you.
The full synthesis report is attached as a zip.
JQ2
We found the issue. The issue is caused by the update of Digital Guardian software tool on our Linux server. The new version of the tool somehow blocks certain functionality of Quartus, so certain IP files cannot be retrieved. Reverting to a previous version of the Digital Guardian solved the problem.
Thank you all for the help.
Regards, JQ
sstrell
Did you try enabling Signal Tap or some other debugging tool?  That entity gets instantiated when you use a debugging tool (sld = system level debug) that uses JTAG access for its use.  Perhaps you accidentally enabled a tool and didn't configure it.  Check the project settings to make sure Signal Tap is disabled.
It looks like you're using the golden hardware reference design (from Rocketboards, so you could also just download a clean copy of the design and recompile it from scratch.
SyafieqS
Hi Zhang,
Try to remove your .stp file in your project file or disable signaltap in your setting file and recompile.
JQ2
The same issue is shown after I disabled the signal tap in Assignments -> Settings -> Signal Tap Logic Analyzer and removed the stp file in the qsf file.
Even I tried to download and compile a clean version of GHRD from (https://rocketboards.org/foswiki/Documentation/Stratix10SoCGSRD), then follow the project build instructions:
make clean && make scrub_clean && rm -rf output_files
make sof
same issue happened in the terminal (see attachment snapshot).
This thread (https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2017/why-does-quartus-give-a-instantiates-undefined-entity-error-when.html ) showed the similar error message. However, it asks me to contact Intel support.
I am compiling the design on our Linux server and this issue suddenly showed up starting this week. When I compare the working syn.rpt and problematic one, I saw difference in the "Synthesis Source Files Read" section (see 2nd snapshot). The working one (right) listed *alt_sld_fab* files as Encrypted Megafunction, while the non-working one (left) showed those files are not Encrypted. Is this the reason that Quartu failed to locate those files later in the report?
 If there is other solutions I can try, please let me know. Thanks for all the help.
Regards, JQ
JQ2
Seems the snapshot in the previous reply does not work, re-pose them here. See attachment.
sstrell
Sanity check: you have a license for Quartus Pro, correct?
JQ2
Hi Sstrell,
Yes, we have valid license for Quartus Prime Pro.
Regards, JQ
SyafieqS
Hi Zhang,
What if you start from scratch, clean all databases (deleting qdb and trying to resynthesize) and recompile or
shortening long directory names eg:
test_pcie_ptile_ast_0_example_design_gen3/ to test/ and recompile.
SyafieqS
Hi Zhang,
Any update on this?
JQ2
Hi SyafieqS_Intel,
I tried to compile the GHRD project from scratch, and also shorten the project directory, still same error is shown. We also tried to compile using latest Quartus Prime Pro 20.4, same error. I attached the *.syn.rpt here.
Thank you for any advices.
SyafieqS
Hi Zhang,
I ran quartus synthesis flow from release 20.2 and 20.4 of your design file, and both completed successfully.
Not much I can do, specially if the problem is not reproducible.
In the warning, I can see there an empty module, search for all file containing that module as the name. Possibly, there is an empty file that is read-only such that Quartus cannot write the real content into it?
Another way is try to reboot your server and rerun through the Quartus flow.
JQ2
Regards, JQ
SyafieqS
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
