I compiled 5GNR software and trying to run testcases on TESTMAC appliacation for L1 Layer
The ouput of PHY console is exiting with an error messege as following:
The executing program located in /root/5G_Compilation/bin/nr5g/gnb/l1/l1app
pTablePath=/root/5G_Compilation/bin/nr5g/gnb/l1/table/
phy_prach_init_api:
ePreambleFormat = 0, config error!
phy_prach_init_params: ERROR ePreambleFormat [0] nL_RA [0] is not valid
Cleanup after [PID] 6554
rm: cannot remove ‘/mnt/huge/*’: No such file or directory
And one more error is
I am getting the below error as well in PHY console
5GNR Timer Mode
PHYDI-START[0]: Mode: 1, Count: 44, Period: 10, Numerology: 80
phydi_start phy_bbupool_reset: TODO
gnb_start_fpga: nTimerMode[1] gFpgaStarted[0]
probe FPGAs
init fpga fec CfgInfo failed
Error opening the dev node file 1
None FPGA found!
ICC Software version used:
icc --version
icc (ICC) 19.0.3.206 20190206
Copyright (C) 1985-2019 Intel Corporation. All rights reserved.
dpdk version : 18.08.
I will provide if any information needed in the follow up mail.
Thanks for the reply
At this point of time we are not using any hardware, Not using FPGA Dev-kit and Quartus.
Compiling 5GNR software on Intel Xeon High end Server and testing the L1 Application created by compiling the code.
Please refer to 603577-flexran-5gnr-ref-solution-phy-software-doc-v18-12!
Open pages.html, go to chapter 4. Compilation tools 4.1 Compilation. There are detailed compilation steps in this chapter and followed by testing.
I am attaching Zip file of this or you can go to web.
We are facing issues in testing the L1 layer after compilation.
Contact person from intel : Li, Minjun <minjun.li@intel.com>
Bhavani
