6307 Discussions
Error with Quartus (intel) on windows 10
IGrou4
During the running of Quartus Prime II, with UniPHY utility for generating a DDR3 controller, the error is displayed:
Error during execution of "<Intel® Quartus Prime installation>/nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/emif/2...
How can I fix this error?
sstrell
The link you posted does not work. Are you talking about an error during compilation in Quartus or Nios code compilation? It's not clear when and where you are seeing this error and what you're doing at the time.
#iwork4intel
ABara8
Hi, i had same issue and found solution on
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Using-Quartus-19-1-Lite-on-Windows-10-Platform-Designer-failed/td-p/695989
basicly you need to install some additional pacages to your WSL on Windows. For Ubuntu/Debian:
  • sudo apt install wsl dos2unix make
