6410 Discussions
Error with "quartus_sh" command after interface planner
Junyong
Hi all,
After interface planner, I extracted the tcl file from the tool.
When I put the command into Tcl console in my project, I encountered the error message below:
Wat command I tried input in the Tcl console was as follows:
Junyong
SyafieqS
Have you set your PATH environment variable to the bin directory of your quartus? Try this and then re-run
Considering you're using Linux:
export PATH=$PATH:<installed_quartus_directory>/<version>/quartus/bin
On Window
1) Open up your command prompt (cmd)
2) Type set PATH=%PATH%;C:\altera\12.1\quartus\bin
Change the back party of the PATH after ';' according to your quartus installation directory
Then try to run quartus_sh again
Similar issue found out that might be helping.
https://community.intel.com/t5/Intel-Quartus-Prime-Software/cannot-execute-quartus-sh-in-command-line/td-p/153115
SyafieqS
On Window
Junyong
Hi SyafieqS,
Thank you for your reply.
I could run the generated tcl file with the following add-on window.
Thank you for your help.
Junyong
FvM
you are trying to run quartus_sh in Quartus tcl console, but it should be run in Windows command window. If you enter a command in tcl console, you are already inside Quartus tcl shell.
SyafieqS
May I know if there is any update from previous reply?
Junyong
Thank you for your reply, SyafieqS.
The issue was resolved as I replied to your previous reply.
Thank you for your help, again!!
Junyong
SyafieqS
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
