6020 Discussions
Errors in build GSRD for Agilex 7 F-Series Transceiver-SoC DevKit
MarcoWu
Hi:
I am rebuilding the GSRD of Agilex 7 SoC by following the steps of https://www.rocketboards.org/foswiki/Documentation/AgilexSoCGSRD#Building_the_GSRD_for_the_DK_45SI_45AGF014EA_Version
and so far, I am facing some problems as the description below.
Problem by following the Labs of Agilex in Rocketboard.
In this Rocketboards Project, I have modified the Makefile for correct the address.
INTEL_CUSTOM_IP_LINK = "https://releases.rocketboards.org/release/intel_custom_ip/$(INTEL_CUSTOM_IP_TARBALL)"
to
INTEL_CUSTOM_IP_LINK = "https://releases.rocketboards.org/intel_custom_ip/$(INTEL_CUSTOM_IP_TARBALL)"
Errors when I did
Setting Up Yocto Build System
-Erros:  No Conf/bblayers.conf file.
PIC: Please check the attached file.
Build Yocto
- bitbake_image
There are several errors:
- ERROR: Nothing PROVIDES 'u-boot-socfpga'
- ERROR: Nothing PROVIDES 'hw-ref-design'
- ERROR: Nothing PROVIDES 'device-tree'
- ERROR: Nothing PROVIDES 'console-image-minimal'
Please help to check if there is anything I have to known.
Best regards
Marco Wu
mabdrahi
I pickup some reference info from discussion previously
Start from "Building the GSRD for the DK-SI-AGF014EA Version" section.
mabdrahi
Im reproducing it.
Will update to you by today
mabdrahi
the issue is reproducible
I will check it
mabdrahi
Hi Marco,
Give me sometime to debug.
I found a useful link from stackoverflow and i will try the solution
https://stackoverflow.com/questions/48652982/bitbake-nothing-provides-error
Please stay tune
mabdrahi
Hi Marco,
Can you rerun the step because i successfully solve the problem when rerun the compilation
mabdrahi
Hi Marco,
Can you try to recompile at your side. se i manage t compile it.
I dont do anything i the code. I seem updated during running below
cd agilex_gsrd
export TOP_FOLDER=$(pwd)
export PATH=`pwd`/gcc-arm-11.2-2022.02-x86_64-aarch64-none-linux-gnu/bin:$PATH
export ARCH=arm64
export CROSS_COMPILE=aarch64-none-linux-gnu-
sudo ln -sf /bin/bash /bin/sh
cd $TOP_FOLDER
cd gsrd_socfpga
. agilex7_dk_si_agf014ea-gsrd-build.sh
build_setup
cd $TOP_FOLDER/gsrd_socfpga
. ./poky/oe-init-build-env agilex-gsrd-rootfs/
bitbake_image
mabdrahi
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
