5931 Discussions
Ethernet MAC/PHY (LAN91C111) with Stratix II
Hello everybody,
I’m a French student in electronics engineering.
I’m trying to use the Ethernet MAC/PHY (LAN91C111 device) IP with Nios II but I have some problems with the pins assignments in Quartus II software (v9.0).
My board is a stratix ii with ep2s60f1020c3 FPGA.
Can you tell me why I can’t find the System Control Bus pins T20, T21, T25, T26 and V26 indicated in the stratix ii dsp development board reference manual when I use the pin planner of Quartus for ep2s60f1020c3 FPGA?
Can you tell me what other pins assignments I could make for these pins?
Thanks in advance.
Cordially,
Samson Bossé.
Ethernet MAC/PHY (LAN91C111 device) is not an IP : is an IC.
You have to assign signal to pins according to the documentation : page 2-25 of the reference manual.
Cordially (Cordialement ne se dit pas, on dit Best Regards !)
Bonne Journée !
