Is it possible to implement Ethernet communication on a MAX10 device that is not connected to an external RAM?
I tried the example "Simple socket..." using NIOS II, TSE, uC-OS with Niche stack, but this implementation requires more than 350Kbytes of RAM. I only have 128Kbytes of internal RAM.
Does anybody know about any "TCP-IP like" stack implementation that doesn't require an OS?
Thank you for your help!
HI,
TCP/IP is likely implemented in software application that run in OS environment.
Whatever Max10 Ethernet example design that Intel FPGA have is available in below link. You can checkout below link
dlim
