6408 Discussions
F2SDRAM : mSGDMA endian issue and SDRAM reading/writing issue
CAlex
New Contributor II
Hi
I'm working on CycloneVsoc Dev Kit baremetal system
Now I want to use F2H sdram to transmit my data.
The draft system Interconnection:
HPS host master
  |    host order
SelfIP write  -------ST----------| SGDMA |--------MM------------->  SDRAM
SelfIP read  <-------ST---------| SGDMA |--------MM-------------     SDRAM
do I need to transfer the Endian for the SGDMA?
or is there any setting to let avalon ST using little endian?
As for HPS,
HPS view of mmap is MPU one, so the address of SDRAM is from 0x00100000 to 0xC0000000, according to HPS UG,
is that the physical address or vertual one?
what is this SDRAM stands for ,? Is it the ddr3 chip on this board?
If it is, is that the place where my codes are?
how should I put/get data to sdram within and beyond this scope from HPS?
CycloneVsoc address map
Reguards
Alex
aikeu
Hi CAlex,
I think you can use the same software code from this design example as reference to perform the transfer for your baremetal application:
https://community.intel.com/t5/FPGA-Wiki/MSGDMA-design-example/ta-p/735335
The sdram is refering to the external sdram which is the DDR for your case.
If checking that specific start address for your baremetal application which loaded to the DDR, you can see the same application content which you have built.
Aik Eu
CAlex
New Contributor II
Hi
I cant use this example for I only get lite edition.
aikeu
Hi CAlex,
Maybe can check out this example link which is similar to the previous link showcasing msgdma using Nios as reference.
https://www.macnica.co.jp/en/business/semiconductor/articles/intel/129345/
Aik Eu
aikeu
Hi CAlex,
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Aik Eu
aikeu
Hi CAlex,
Aik Eu
aikeu
Hi CAlex,
Aik Eu
aikeu
Hi CAlex,
Aik Eu
aikeu
Hi CAlex,
I will close the thread if no further question.
Aik Eu
