6261 Discussions
FALC56 E1/T1/J1 Framer; Intel Bus Interface (HPI) to SPI bridge via FPGA
DanielHC
I'm looking for an Intel Microprocessor 8-bit bus interface converter/bridge to SPI that I'll implement at the FPGA in order to convert the FALC56 bus to another system SPI communication.
Also, does the intel Micropcoessor 8-bit bus interface have other names?
EBERLAZARE_I_Intel
Unfortunately we do not have this available on our PSG websites. We may not be able to support your further on this ticket.
I found this on a forum on the item that could be what you looking for:
https://www.edaboard.com/threads/the-first-8-bit-microprocessor-intel-8008-i8008.216692/
We apologies for the inconvenience, I hope we have provided you enough.
EBERLAZARE_I_Intel
I am unsure on your request here, are you looking for a soft or hard processor for your system?
In our Platform Designer in Quartus, our PD will auto add a bridge to satisfy any mismatch bus address width in your Qsys design, but we need more info on what you're trying to achieve.
DanielHC
We are using FALC56 E1/T1/J1 PEF2256 (full p/n: PEF2256EV22), Intel's component.
On the datasheet, I noticed this component is known to use "Intel Microprocessor 8-bit bus interface".
I'm looking for an "Intel Microprocessor 8-bit bus interface" to SPI converter (bridge) that I'll implement at my FPGA (VHDL).
This bridge should convert "Intel Microprocessor 8-bit bus interface" (parallel) to SPI (serial) and vice versa.
I'm asking here because I didn't find any pseudo code or examples on the internet regarding the "Intel Microprocessor 8-bit bus interface" protocol especially how to convert it to SPI.
Any documents, code examples, or even all the bridge code will help me a lot.
EBERLAZARE_I_Intel
I was checking on the host core, if you're using a soft core, which is the Nios II core for example it should look like this:
https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-examples/horizontal/exm-spi-bridge.html
If that is not what you're looking for, I think you may need to file a separate forum on your device in the correct topic.
DanielHC
Thanks for the example, but I'm also looking for some "Intel Microprocessor 8-bit bus interface" bridge. so I could combine it with the SPI bridge that you sent me.
Any documentation or examples regarding "Intel Microprocessor 8-bit bus interface" will be grate
EBERLAZARE_I_Intel
EBERLAZARE_I_Intel
Do you have any other questions related to our Intel FPGA?
EBERLAZARE_I_Intel
If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
