6311 Discussions
FIFO Block Implementation error
AAjit2
I tried writing my own version of FIFO block but I can't seem to understand how the read data stages shift out of the FIFO pushing down the stages above it all the while continuously writing into the FIFO from the outside. To give an example say I write a b c into the FIFO at 1 2 3 position, at c I start reading the data so a comes out and b becomes 1 and c becomes 2. However while I'm reading out data, I want data to be written in and not at 4 because 3 is now empty as c is in 2. So how do I write the code such that both processes happen side by side yet the shifting is also happening. Any help with this is much appreciated.
GuaBin_N_Intel
To my best understanding in FIFO, it should have two separate control logic blocks to perform read and write on a RAM. It uses a pointer to determine which address to do the read or write operation. Hence, NOT really need shift the data from one location to another.
GuaBin_N_Intel
AAjit2
Wait, so if the data isn't shifted, how does the read data removed once it's read out? With the pointers it would seem as though it just keeps reading up until the FIFO is full without clearing the previous data.
AAjit2
Ahh okay! Thank you so much, this clears it up quite a bit!
GuaBin_N_Intel
It won't be removed unless you reset the RAM block completely or overwrite old data with new data.
