5703 Discussions
FPGA MAX10 Device Outer Case Component Dimensional Tolerance.
MHASI2
I would like to ask FPGA MAX10 device outer case dimensional tolerance for each of the components below.
  1. 10M08SAU169I7G
  2. ​10M50DAF256I7G
I would like to know the the dimensional tolerance of the each one of the components listed above.
Looking forward for the response.
Thank you.
AnandRaj_S_Intel
MHASI2
​Hi Anand,
Thank you for your response.
I would like to ask a few questions regarding the data from the link above
  1. Can I have the description about what are the MO-275 Variation: FFAA-1 and MO-192 Variation: DAF-1.
  2. What is the dimensional tolerance of the one FPGA MAX10 components upon delivery? For example, the length and the width for the MAX10 components are 11.00mm with tolerance +-0.1mm each. What is the Intel standard dimensional tolerance for MAX10 components?
Looking forward for the answer.
Hasif
AnandRaj_S_Intel
Hi Hasif,
Please refer attached documents for tolerance value.
All dimensions and tolerances conform to ASME Y14.5M – 1994. check below link
http://www-eng.lbl.gov/~shuman/NEXT/ANGEL2/ASME-Y14-5M-2004-Dimension-Ing-and-Tolerancing.pdf
Anand
AnandRaj_S_Intel
MHASI2
​Hi Anand,
Thank you for sharing the the information documents regarding the dimensional of the components.
From what I have understand  from the documents given above, the physical property of the components are:
a) 10M08SAU169I7G
The outer component  dimensional tolerance for 10M08SAU169I7G is D=11.00mm +- 0.15mm and E=11.00 mm +- 0.15mm.
b) 10M50DAF256I7G
The outer component dimensional tolerance for  10M50DAF256I7G si D=17.00mm +- 0.20mm and E=17.00mm +- 0.20mm.
Please correct me if I'm wrong.
Hasif
AnandRaj_S_Intel
Hi Hasif,
Yes,
  1. U169 ->size =11 mm × 11 mm-> pitch -> 0.8 mm with tolerance of 0.15 mm
  2. F256-> Size =17 mm × 17 mm-> pitch -> 1 mm with tolerance of 0.20 mm
Anand
