6307 Discussions
FPGA example to wirte data to SSRAM/SDRAM in Cyclone III starter kit?
I want to use VHDL/verilog to write some simple data to the SSRAM/ DDR SDRAM in Cyclone III starter kit, then use control plane to read the data out.
Anyone has VHDL/verilog examples? just a simple write is O.k. I don't need read etc.
Thank you very much!
Are you sure that you want to use a hardware language to read and write to off-chip mem?
I would use a simple c program in the nios environment. For starters, you could use the IOWR and IORD functions to write and read to/from memory. The address range for the memory is specified in sopc builder.
Hope that helps.
Andrew
Thank u, I am not sure, I am not familiar with how to use nios to read and wirte off-chip memory.
--- Quote Start ---
Hope that helps.
Andrew
--- Quote End ---
Here's an example of a function to test the off-chip mem. It won't completely test the memory, but I think it is sufficient for what you're doing. MEM_TEST_VAL is whatever you want it to be as long as it's not bigger than 32 bits. Have fun.
int ddr2_mem_test()
int i;
int error_count;
int readbyte;
error_count = 0;
// Write to the memory needed.
for(i=0; i<(MEM_SPAN); i++) {
IOWR_32DIRECT(DDR2_SDRAM_BASE, i, MEM_TEST_VAL);
// Read back and verify data.
readbyte = IORD_32DIRECT(DDR2_SDRAM_BASE, i);
if (readbyte != MEM_TEST_VAL)
error_count++;
return error_count;
I also want to read data from SSRAM using verilog, but can not succeed.
Does anyone can share this code to read /write data from/to SSRAM? thANKS. It will be greatly helpful. pleaseeeee share here or send to chrisfzhang@gmail.com if possible.
