6387 Discussions
FPGA hardware result different from simulation
I may be wrong, but I think this is where I should post this question. I'm working with the max10 development board .
https://www.altera.com/products/boards_and_kits/dev-kits/altera/max-10-fpga-development-kit.html
I have written a piece of code for a counter and pwm generator which uses altera's pll megafunction. I believe the code is right and there shouldn't be any latches. Simulation shows what I am expecting, but when I program this to the FPGA, the results on the oscilloscope is completely off. I am expecting a 500Hz pwm signal, but I am getting something in the 1.5-2Mhz range, not a square wave and very jittery. I don't have pictures right now, I will try to get them up soon.
I suspect my problem is related to the way I've set up the pll or assigned the pins. Below is the code I've written. Is there anything else I can provide that would help troubleshoot this issue.
My global clock is connected to M9 from the pin out and that should be the onboard generated 50MHz.
module fc_top (
//Reset and Clocks
input clk_50,
input rst_n,
input pwm_up,
input pwm_dwn,
//LED PB DIPSW
output pwm_out
// wire clk;
wire clk_256khz;
wire lock;
reg pwm_o;
// altclkctrl altclkctrl (
// .inclk (clk_50), // altclkctrl_input.inclk
// .outclk (clk) // altclkctrl_output.outclk
//used max divisor, 10000 gave 500hz output
pll pll_inst (
.areset ( rst_n ),
.inclk0 ( clk_50 ),
.c0 ( clk_256khz ),
.locked (lock)
//PWM module
localparam COUNTER_WIDTH = 9;
//localparam COUNT_MAX = 9'b111110100; //500
//localparam COUNT_MAX = 500; //500
reg [COUNTER_WIDTH - 1:0] counter;
// at 500hz (=2ms), 1ms = 250count
//reg [COUNTER_WIDTH - 1:0] duty_cycle = 9'b011111010; // change to whatever bit gives 50% duty cycle. ini of pwm
reg [COUNTER_WIDTH - 1:0] duty_cycle; // change to whatever bit gives 50% duty cycle. ini of pwm
//user can use pushbutton to increase/decrease pwm duty cycle.
//not sequential, this block only active if sensitivity list is true.
//so if user does nothing, duty_cycle should remain unchanged.
// at thet start and while counter is less than duty cycle, output is high
// when greater than duty cycle output is low. reset when max reached.
// reset active high? loook for falling edge
always @ (posedge clk_256khz) begin
if (rst_n == 1) begin //rst and lock cannot be 1 at the same time. a rst occurs and requires ~70ns before we get lock
pwm_o <= 1;
counter <= 0;
duty_cycle <= 255;
end else if (lock == 1) begin //I only want output to change when locked.
if (pwm_up == 0) begin // push buttom press = pulled low.
if (duty_cycle + 63 <= 511) begin
duty_cycle <= duty_cycle + 63;
end else begin
duty_cycle <= 511;
end
end else if (pwm_dwn == 0) begin
if (duty_cycle - 63 >= 255) begin
duty_cycle <= duty_cycle - 63; //if duty_cycle 256, leave it. this will have to change to represet push buttons later.
end else begin
duty_cycle <= 255;
end
end else begin //else if (pwm_up == 1|| pwm_dwn == 1) begin
duty_cycle <= duty_cycle;
end
if (counter < duty_cycle) begin
pwm_o <= 1;
end else begin // counter on second part of cycle, will auto wrap around
pwm_o <= 0;
end
counter <= counter + 1;
end else begin
counter <= counter;
end
end
//pwm_out will always receive value of pwm_o, anytime all time.
// pwm_out is wire to outside top module, pwm_o is register holding value.
assign pwm_out = pwm_o;
endmodule
a few thoughts on this:
  • the "always" block is not sensitive to the reset; should be no reset in the real design, though, just something which would behave strange in the simulation
  • does that PLL actually support a 256 kHz output clock? Sounds mighty low for a FPGA PLL. Was there any warning in the MegaWizard/IP Catalog?
  • the reset signal seems to be active-low (I assume so because the name is "rst_n"), but your reset condition is "if (rst=1)"; typo?
  • I assume "pwm_up" and "pwm_down" are push-buttons; are they debounced?
  • are the "pwm_up" and "pwm_down" input signals maybe floating? If you accidentally mapped them to floating pins, they would wildly change the PWM duty cycle, which might cause the described behavior; actually, same for all input signals
I agree most of these points are unlikely to cause the described behavior, but maybe it's a combination of several effects...
I didn't see your simulation, so I have to assume it's correct. Also, I assume there are no timing issues. You didn't mention a static timing analysis, but 50 MHz sounds doable for just about any design in a MAX10.
One more thing: please consider using code-tags when posting code; your code lost all indentation and is hard to read when being posted as plain-text. Code tags can easily be inserted using that toolbar button with the "#" symbol.
GooGooCluster
Hi GooGooCluster,
Thank you for the response. I figured it out. I messed up at the third point, the reset signals. I also ran into problems with setting/changing duty cycle and after some time, was a result of not debouncing.
I have verified everything to be working, so the points you described were on point. =]
I will look for the code tags in the future, thanks!
I would consider this resolved, do we need to flag this thread or anything?
You got me. No idea. I think there's no way to mark a thread as resolved...?
