6334 Discussions
FPGA to HPS bridge on Agilex 7
Mikhail_a
Hello
I'm trying to read and write from and to HPS SDRAM on Agilex 7 board
I have this configuration of fpga2hps interface:
On the other side I have two msgdma ip cores for MM to Stream and Stream to MM transfers. But MM to Stream DMA doesnt work as its busy bit is permanently set to 1. As I understood from reading the forum it can be related to fpga2sdram bridge which is not initialized right.
So my question is:
1) how to make sure my  fpga2sdram bridge is in the right condition
2) what can be wrong with the MM to Stream DMA?
DMA settings:
FPGA to HPS AXI bus state:
Artavazd
Sorry that was me but from another account. We can close this thread.
EBERLAZARE_I_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
