Fix an error
SPere43
Hello guys.
Im try compile a example hello_world in a kernel.
But i have a error:
Error: Qsys-script FAILED.
I already checked the forum, but I didn't find any compatible solution.
Intel FPGA SDK
AoCL 19.1.0.670
Can you help me to fix it?
MEIYAN_L_Intel
May I know do you using the terasic board: DE1-SOC as I found the information from the .log file.
It seems like that board BSP is not compatible with Quartus v19.1.
Could you try to check the instructions provided by terasic to see the version of Quartus used that is compatible with your BSP.
SPere43
Yes, exactly.
I'm using this FPGA: http://de1-soc.terasic.com/
What version you recommend? 16.1?
SPere43
MEIYAN_L_Intel
You may need to follow the instruction in the document below:
https://www.terasic.com.tw/attachment/archive/836/DE1SOC_OpenCL_v02.pdf
As I found Terasic have provide BSP in OpenCL SDK v14.0 and v16.0 shown in link:
https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&No=836&PartNo=4
I would recommend use OpenCL SDK v16.0 as BSP provided.
For more information about OpenCL SDK v16.0, you may need to refer the link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/archives/ug-aocl-getting-started-16.0.pdf
SPere43
Hello MeiYanL,
Unfortunately, I reinstalled everything and set the version to 16.0 as requested.
Unfortunately I still have errors and I don't know what to do.
SPere43
MEIYAN_L_Intel
From the message, you may need to obtain the license file for the OpenCL SDK software from Altera Self Service Licensing Center.
For more information, you may need to refer the document as link below:
