5892 Discussions
Flex would like Intel do FA for EP4CGX50DF27I7N
JPeng7
We captured some failed boards with the “Spare Parts final” failure step on 15235 model at FT.
  • checked the related components no soldering issue and cosmetic issue no found.
  • Take 3pcs failed boards to x-ray, no open or short issue found.
  • Reheat the failed U18 BGAs, test still failed.
  • Re-mounted the failed U18 BGAs ,test still failed.
  • Remove the failed u18 and remount it in the passed board, the fail step and information is same.
Suspected the U18 BGA working abnormal. After replaced the suspect BGAs , the boards passed test process. So confirm that the fail symptom will follow the suspect BGAs.EP4CGX50DF27I7N.jpg
NurAiman_M_Intel
Thank you for contacting Intel community.
I will continue to support this case through Forum private message.
Aiman
JPeng7
Hi, Support team
Pls. advise the progress, thanks!
Jimmy
JPeng7
Hi, Intel Support team
Could you help response this case asap? Thanks!
Jimmy
Zawani_M_Intel
Hi Jimmy,
I have share some update for the current status for this case via private message.
Please do let me know if you do not receive the message.
Thanks!
Wani
JPeng7
Hi Wani
I received the update but it doesn't what I want to.
Could you please expedite to  publish FA report asap, thanks!
Jimmy
Zawani_M_Intel
Hi Jimmy,
I am sorry my previous message do not provide the info as you required.
I forward the request to internal team to put the case in fast lane.
Wani
