We captured some failed boards with the “Spare Parts final” failure step on 15235 model at FT.
- checked the related components no soldering issue and cosmetic issue no found.
- Take 3pcs failed boards to x-ray, no open or short issue found.
- Reheat the failed U18 BGAs, test still failed.
- Re-mounted the failed U18 BGAs ,test still failed.
- Remove the failed u18 and remount it in the passed board, the fail step and information is same.
Thank you for contacting Intel community.
I will continue to support this case through Forum private message.
Aiman
Hi, Support team
Pls. advise the progress, thanks!
Jimmy
Hi, Intel Support team
Could you help response this case asap? Thanks!
Jimmy
Hi Jimmy,
I have share some update for the current status for this case via private message.
Please do let me know if you do not receive the message.
Thanks!
Wani
Hi Wani
I received the update but it doesn't what I want to.
Could you please expedite to publish FA report asap, thanks!
Jimmy
Hi Jimmy,
I am sorry my previous message do not provide the info as you required.
I forward the request to internal team to put the case in fast lane.
Wani
