Frame Reader configuration
I use DE2 board and TERASIC TRDB_LTM (800x480 Touch LCD)
I attempt to build the following configuration:
NIOS2 that runs the program from SRAM: Works
LCD that is connected to Video Clocked Output IP that is fed from Frame Reader that reads the data from DE2 SDRAM.
The Video interface is configured to 3 planes 5 bit each, parallel. with resolution that is the same as the LCD.
If i connect Test Pattern Generator instead of Frame Reader, then i get the pattern.
If i connect Frame Reader I fail to get any picture.
I'm not sure regarding the configuration of the Frame Reader.
The SOPC configuration of the Frame Reader:
16 bit port.
max width:800
max height:480
parallel planes: 3
serial planes: 1
bits per color plane: 5
As far as i understand the configuration, there is 1 cycle per word.
so words per frame= cycles per frame=800*480=384000 am i correct?
what should i set in the interlacing register (i want to hold all the frame in one place)?
any insights regarding SDRAM configuration on DE2 board? (although i think it works fine)
Thanks in advance.
hi there,
in the video imaging user guide is written the maximum size of the frame is 640X480, u should use a scaler if want a bigger picture...
im also trying to run the frame buffer with nearly the same configurations but i also cant get an image.
greets
I was able to get an image using the example from this thread:
http://www.alteraforum.com/forum/showthread.php?p=83223
i just changed the connections of the example to GPIO that i used for the LTM device.
use the frame reader in my design with the following settings:
Bits per pixel per color plane: 8
Number of color planes in parallel: 3
Number of color planes in sequence: 1
Maximum Image width: 1920
Maximum Image height: 1080
Master port width: 64
Read master FIFO depth: 1024
Read master FIFO burst target: 64
Use separate clock for the Avalon MM master interface: unchecked
Kindly confirm if the following calculations for number the words and the Single Cycle Color Patterns are true or not
1- // Words
IOWR(FRAMEREADER_BASE, 5, 259200); // (1920*1080*8*3)/48= 1036800
2- // Single Cycle Color Patterns
IOWR(FRAMEREADER_BASE, 6, 2073600); // 1920*1080=2073600 number of pixels in the frame
