6393 Discussions
GSRD (Pre-Built Binaries) boot fail Agilex® 7 FPGA I-Series Transceiver-SoC Development Kit
TakaU
I am currently using the Intel Agilex® 7 FPGA I-Series Transceiver-SoC Development Kit (4x F-Tile)
( DK-SI-AGI027FA Dedvice number : AGIB027R31B1E1V),
I have followed the below website to write SD card binaries,
https://www.rocketboards.org/foswiki/Documentation/AgilexSoCGSRDSIAGI027
and wrote JIC Image( ghrd_agib027r31b1e1vaa.jic) to QSPI Flash successfuly.
JIC program log like the bellow
Info (19094): Erasing flash chip select 0 at device index 1
Info (19096): Programming flash chip select 0 at device index 1
Info (19097): Verifying flash chip select 0 at device index 1
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Mon Apr 22 15:01:40 2024
Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 2362 megabytes
Info: Processing ended: Mon Apr 22 15:01:40 2024
Info: Elapsed time: 00:01:51
Info: System process ID: 7314
I set MSEL back to QSPI , start serial terminal and then power up the board,
but no response on the serial terminal (speed : 115200).
Before download JIC program, I observed some message on serial terminal.....
so it may not serial terminal setting.
Is there anything wrong i made with GSRD with Pre-Built Binaries boot?
Jeet14
Please use the pre-built binaries for your development kit(DK-SI-AGI027FA) from below link.
https://releases.rocketboards.org/2024.04/gsrd/agilex7_dk_si_agi027fa_gsrd/
On below link, two board pre-built binaries are given (DK-SI-AGI027FA (AGIB027R31B1E1V), DK-SI-AGI027FB (AGIB027R31B1E1VAA))
Tiwari
Jeet14
Tiwari
TakaU
Thanks a lot of your reply.
Now DK-SI-AGI027FA is up and running.
Probably I did use wrong version jic file.
( this is just FYI....
I used screen as a serial communication program.... but it did not work well.
   For example,  Boot message are  freezed in middle of boot process,
   so I setup minicom that GSRD document prefer.
   Then the Board boot up, and everything is fine now.)
Jeet14
Thanks your confirmation.
With that, I now transition this thread to community support.
Thank you.
Tiwari
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
