General question in PLL
MK_ABQ
New Contributor II
A general question in PLL. I am currently working with an Intel IP which has an I/O PLL. The PLL will be locked once the input frequency is stable. At the same time, it says the jitter tolerance is about 100 ps. It seems contradictory. If am testing jitter, then the period will keep changing and the PLL is not gonna lock. so how does it work?
Farabi
In PLL simulation you cannot introduce jitter as the simulation model not include the jitter factors. There is requirement you need to follow for supplying clock source/oscillator to the PLL input, this spec already cover jitter and skew to make sure PLL working as expected in datasheet.
regards,
Farabi
Mike_Intel
Hello MK_ABQ,
For us to further check the issue, please provide the following details.
  1. What is the model of the Intel Ethernet network card that you are using?
  2. Are you designing a board/system with Embedded network card?
  3. Can you tell us more about this test or project that you are doing for us to assist you or route you to the correct team if needed.
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
MK_ABQ
New Contributor II
Hi Mike,
I am not using an Ethernet IP. I am using a LVDS IP, and interested specifically to understand jitter/PLL behavior. Should I post this question in a different group?
Mike_Intel
Hello MK_ABQ,
Thank you for the update. Since you are inquiring about an FPGA product. I will route your case and thread to the correct group.
Please wait for their reply within 1 to 2 business days.
Thank you and stay safe.
Michael L.
AqidAyman_Intel
Thank you for reaching out to Intel FPGA Community.
Could you share which device are you using?
Aqid Ayman
MK_ABQ
New Contributor II
I am using Arria 10 FPGA. How do I introduce jitter in simulation ?
Farabi
regards,
Farabi
