6374 Discussions
Getting the outputs resulta from a file in real time
SATC
Hello, everyone.
How can I get the results of outputs and registers with the usb cable from a simulation running in real time? I'm trying the Signal Tap but I would like to know about others resources.
Thank you!
SyafieqS
Hi Sarah,
You can use In-System Sources and Probes (ISSP). It allows you to monitor various signals in the design on the device with a JTAG interface. May refer to below link for details related to Design Debugging Using In-System Sources and Probes
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-debug.pdf (pg124)
sstrell
Note that In-system Sources & Probes is only "real-time" as far as how fast signal info is sent over the JTAG connection, so you're talking about kHz speeds.  You're not going to be able to see high-speed signals toggling with ISSP.
Signal Tap really is the main debug tool for looking at signals, through they are frozen at a moment in time.
#iwork4intel
