5487 Discussions
HPS access the Avalon Memory-Mapped whether in pending status
Jacob999
I use Avalon Memory-Mapped (Avalon-MM) interfaces to implement read and
write interfaces for master and slave components. HPS side is master and FPGA side is slave.
I find that HPS software code could not be pending when HPS launch one write/read transmission in waitrequest mode(the Avalon slave asserts waitrequest signal).
In the document description, " A slave asserts waitrequest when unable to respond to a
read or write request. Forces the master to wait until the interconnect is ready to proceed with the transfer. At the start of all transfers, a master initiates the transfer and waits until waitrequest is deasserted."  My question is how about the HPS write/read MM software code, whether also be pending like the Avalon master, how about that scheme need to be configured if we want to pend software code runs on ARM?
JingyangTeh
Hi Jacob
Are you referring to a flow control within the HPS?
For more information on the Flow Control between the Master and Slave you could refer to the document:
https://www.intel.com/content/www/us/en/docs/programmable/683091/20-1/typical-read-and-write-transfers.html
Jingyang,Teh
JingyangTeh
Hi Jacob
Any update on this case?
Jingyang, Teh
JingyangTeh
 Hi Jacob
We did not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Jingyang, Teh
