Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Help With cfi_flash....in de2
Using cable "USB-Blaster ", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x01803138: verified Initializing CPU cache (if present) OK Downloading 01400000 ( 0%) Downloaded 64KB in 1.1s (58.1KB/s) Verifying 01400000 ( 0%) Verify failed between address 0x1400000 and 0x140FCAB Leaving target processor paused
at system library prop prog mem is flash and ro data mem is flash also
using flash to run as hardware...
How to overcome this?
