5239 Discussions
Help me! UDP payload inserter problem,urgent!
I've added a UDP payload inserter and padding from the famous project- Offload example.
I can send a short message through SDRAM->mux with packets from SGDMA component (TS Multiplexer) input4> TSE MAC. So there are no probelm with the TSE. I want to send udp payload through :
prbs generator-> udp payload inserter -> padding -> mux with packets from SGDMA component (TS Multiplexer) -> TSE MAC. But there are no anything on the port.
the code to start the stream is as follows :
int main()
int i;
UDP_INS_STATS *insert_stat;
UDP_INS_STATS *getinsert_stat;
insert_stat->mac_dst_hi = lwip_htonl(0x001AA02A);
insert_stat->mac_dst_lo = lwip_htons(0xACF0);
insert_stat->mac_src_hi = lwip_htonl(0x00112233);
insert_stat->mac_src_lo = lwip_htons(0x4455);
insert_stat->ip_src = lwip_htonl(0xC0A80064);
insert_stat->ip_dst = lwip_htonl(0xC0A80065);
insert_stat->udp_src = lwip_htons(0x07D0);//port:
insert_stat->udp_dst = lwip_htons(0x07D0);
start_packet_generator(GENERATOR_0_BASE, 1472, 0x33557799)
printf("start_packet_generator\n");
start_udp_payload_inserter(UDP_INSERTER_0_BASE, &insert_stat
printf("start udp payload inserter %d times \n",i);
usleep(10000);
return 0;
Can anybody tell me the way to solve the probelms.Thank you a lot, give my best wishes to you.what 's problem,
I have solve the problems. I have changed the mulplexer of Ethernet,the orignal code is OK. But now I meet another problems. The Avolon st is 32-bit, but my source data is bytes, the payload count may be 491 or other number which can't be divided by 4. Does anybody have a good ideas to deal with the problems. Pading zero can't solve the problems!!!I think so. Give my best wishes to you
