5892 Discussions
Hi, I am using Cyclone iv ep4ce6e22c8n fpga development kit from dueprologic. When i try to flash the code it is taking more than 10 minutes to complete the flashing. Can you please answer to this question? Regards Hareesh
HMoha11
ShafiqY_Intel
Hi HMoha11,
May I know which configuration file you are using (eg. .pof, .sof, .pof)?
Can you change your JTAG frequency to the 6MHz (default value)?
HMoha11
Hi MShafiq,
Thanks for your reply ,
I am using .pof configuration file. I think the board doesnt support other configuration like .sof
I will try reducing JTAG frequency.
May i ask you one question? Why do we need to reduce the clk freq.?
Hareesh
ShafiqY_Intel
Hi Hareesh,
Sometime the signal integrity and timing prevents operating at 24 MHz. Thus, the optimum recommended value is 6 MHz (default value).
In addition, the TCK frequency cannot change using the USB-Blaster download cable.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd11142008_293.html
