Hi HMoha11,
May I know which configuration file you are using (eg. .pof, .sof, .pof)?
Can you change your JTAG frequency to the 6MHz (default value)?
Hi MShafiq,
Thanks for your reply ,
I am using .pof configuration file. I think the board doesnt support other configuration like .sof
I will try reducing JTAG frequency.
May i ask you one question? Why do we need to reduce the clk freq.?
Hareesh
Hi Hareesh,
Sometime the signal integrity and timing prevents operating at 24 MHz. Thus, the optimum recommended value is 6 MHz (default value).
In addition, the TCK frequency cannot change using the USB-Blaster download cable.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd11142008_293.html
