5690 Discussions
How can I perform warranty repair?
STu1
We bought a "Cyclone V GT FPGA Development Board" at 2018/10/9.There was a problem with the IO test.How can I perform warranty repair?
Nathan_R_Intel
Hie Can you please re-run the test with the loopback card plugged in to HSMB. I believe currently you have loopback card plugged into HSMA. Please unplug it and plug it into HSMB and rerun test and confirm if the failure still exist. Regards, Nathan
STu1
Hi Nathan,
The failure still exist.
We used our design and assign the input/output pin to HSMB(ex.pin1,pin2,pin3).
It can be used, but it won't work after a period of use.
We need to re-assign IO to another HSMB pin.
So I using loopback card to test and have failure.
Nathan_R_Intel
Hie, ok could you provide the dev kit serial number.
STu1
Hi Nathan,
I can find two serial numbers on the back of the board.:
(1)6XX-44179R-0B
(2)5CPCIe 00002013
Which one you want?
Nathan_R_Intel
Thanks for your response. Another Intel representative will reach out to you soon. Regards, Nathan
STu1
Hi Nathan,
Thanks your help!
AR_A_Intel
Hello, I’m helping on the warranty repair. May I have the copy of invoice showing ship date? This is for further warranty checking. And you can also reply/attach your file in private message.
STu1
Hi AAbd,
I sent message to you and attached the invoice file.
AR_A_Intel
Hi Sir, Thanks for your update. I'm now check your issue with our Customer Service Team and it normally takes about 1~2 working days to verify and please expected some delay in our respond.
AR_A_Intel
Hi Sir Upon confirmation from Customer Service team, your Cyclone V GT FPGA Development Board is out of warranty. The kit was shipped on 8/2018 and the warranty period for dev kit is 90days starting from shipment date. Regrettably, we couldn’t proceed for the warranty repair claim. Please accept my apologies for not being able to assist you fully and thank you for patience and understanding on this matter
