I used MAX10 FPGA Device 10M50DAF484C7G configuration with Altera USB Blaster.
How can i resolve ploblem "Error (16353): Expected the Max 10 device at index 1 to be of type analog, but detected device of type compact instead. Ensure that you are using the correct programming file." message.
MAX10 FPGA Configuration pof or sof file with only USB BLASTER II?
Can't I use USB BLASTER?
Hi Kim,
The error message indicates that you are not using the correct programming file for the configuration. Can i have full picture of your setup?
- What configuration scheme you are using.
- How many devices in the board?
- what is the programming file generated and programmed into this?
Thank You.
