5707 Discussions
How can i use differential to Single Clock input for Agilex FPGA Device using Intel PRO 21.4 Tools
ArjunTechM
I am currently working with Agilex FPGA Device for one of the NVM Storage device project.
I need to use external differential input clocks which are to be used for different interfaces.
I need to convert them into single and use internally.
Can i have any Differential to Single clock convertor IP available in IntelPRO 21.4 Version tool.
Also am in need of clock buffer IP to use for the same project.
Please suggest me proper IP to use these.
Thanks inadvance.
Best Regards
Ram
AqidAyman_Intel
Hello Ram,
You may find it in the IP Catalog inside the Intel Quartus Prime Pro. You also can refer to the documentation regarding the Clock Control Intel® FPGA IP Core.
Aqid Ayman
Farabi
To use diff signal to single IO, you just tap either P or N of the diff pin, then it will become single ended signal. You dont have to use any IP to convert it.
regards,
Farabi
ArjunTechM
Thank you Farabi.
One more doubt , How can i use buffer IP Whether it may be Clock Buffer or IO Buffer in the Intel PRO Tool
Best Regards
Ram
AqidAyman_Intel
Hello Ram,
Aqid Ayman
