Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
How do I get Arria10 design to compile on Quartus 18.1.2?
I recently downloaded the Arria 10 device on my Quartus18.1.2. The problem I run into is that it seems to require Quartus18.1.0 based on this compilation error :
Error(114006): Database file c:/altera/18.1/quartus/common/devinfo/20nm/ddb_nightfury_info.ddb, created by Quartus II Version 18.1.0 Build 222 09/21/2018 SJ Pro Edition software, not compatible with current Quartus Prime Version 18.1.2 Build 277 02/12/2019 SJ Pro Edition software
This only happens on Arria10 because I can compile with Stratix10 and Cyclone10.
Highlighted
Retired Employee
Since you installed Arria 10 after patching 18.1, the software might be messed up. I'd uninstall Quartus, re-install it, installing A10 at the same time, and then patch to 18.1.2 last.
#iwork4intel
Hi Vuk,
Did you have the base software installed first? Then you installed the 277 patch?
Isaac.
Highlighted
Hello all,
yes that's what i did, i installed 18.1 (which is 222) then patch to 277. After that i installed arria10 device. I could follow sstrell advice but any work around so i dont have to uninstall?
thanks
Highlighted
Hello Vuk,
I have a workaround for you. Could you please uninstall the patch? Then you have the base of Quartus, install the Arria 10 device.
After you complete this, you can install the patch again and try to compile it again.
To uninstall the patch look follow the next link [1].
[1] https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/soluti...
Best regards.
Isaac.
Highlighted
Hello Vuk
Did the solution work?
Isaac.
