If a new component is added into SOPC and SOPC regenerates the system. But the pin assignments does not show newly added component? thanksLink Copied
Did you re-instantiate the component???
also the new pins must be present in the entity or module and then it should be re-synthesized to see the new pins in the assignment editor box...- Mark as New
Ok
I will try to give you an advice
Topic Options
