5993 Discussions
How to add pin assignments for a new added component?
If a new component is added into SOPC and SOPC regenerates the system. But the pin assignments does not show newly added component?
thanks
Did you re-instantiate the component???
also the new pins must be present in the entity or module and then it should be re-synthesized to see the new pins in the assignment editor box...
Ok
I will try to give you an advice
