5697 Discussions
How to boot board from EPCS with NIOSII code running from SDRAM?
BXia
I found a demo DE0_NANO_SDRAM_Nios_Test from this topic: https://community.intel.com/t5/FPGA-SoC-And-CPLD-Boards-And/Can-t-get-DE0-nano-board-to-boot-from-EPCS-with-NIOSII-code/td-p/698479 , which is provided by Intel, based onn Intel descrption, the nios ii code runs from SDRAM (not on-chip memory) .
I had two questions when running this demo:
1. I used Quartus lite v18.1, I tried to download the .elf file, but got the error shown in this screenshot, how this happened? I used wrong Quartus?
2. Is it possible to add the .elf to .sof, then convert .sof to .jic? If yes, how to do it?
I know how to add the .elf to .sof then convert .sof to .jic for the project that nios code run on on-chip memory, but I don't know how to do it for the project that nios code run on SDRAM.
Thanks in advance, hope someone can help me.
hareesh
=> pls follow bellow video for combining the .elf into .sof file.
 Combining a Nios® II ELF executable into a Hardware Project SOF file
=> .sof to ,jic file converting process document sharing here
https://www.intel.com/content/www/us/en/docs/programmable/683299/current/converting-sof-to-jic-files-in-the-software.html
if you have any doubts or any issues in this process let me.
Thank you,
BXia
Hi Hareesh,
Thanks for your advice.
My first demo which the nios ii code runs on on-chip memoy: I followed the steps in the video, combined the .elf into .sof, convert it to .jic, and run successfully without problem.
However, the second demo(DE0_NANO_SDRAM_Nios_Test provided by Intel) which the nios ii code runs on external SDRAM memory: I tried to follow the steps, in the SDRAM contoller of the qsys system, I can't find the two options to check in the "Memory Initialization", as shown in this screenshot, do you have any idea?
Thanks again.
hareesh
Hi
can you pls share screenshot of your issue or platform design file
thanks,
BXia
I attached the complete DE0_NANO_SDRAM_Nios_Test project here, you can open to see the platform design file clearly.
Or please help check if the nios ii code is really runs on external SDRAM.
Thanks again.
hareesh
is it your own design or downloaded from any where?
because SDRAM controller not showing in my IP catalog. how did you add that IP in design
BXia
Hi hareesh,
Actually the design is provided by Intel as I said in my first thread,  this is the original source: https://community.intel.com/t5/FPGA-SoC-And-CPLD-Boards-And/Can-t-get-DE0-nano-board-to-boot-from-EPCS-with-NIOSII-code/td-p/698479
And I opened the design with Quartus lite v18.1, I can see the SDRAM controller without any problem.
hareesh
hareesh
We do not receive any response from you to the previous question/reply/answer that I have provided. pls confirm, do you have the issue or not.
hareesh
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
