I used the GHRD to start my own project, yet I need to reflesh the device tree to fit my design.(personal IP core and new HPS settings)
In SOC- EDS tool box soc2dtb there are three files needed:
1. soc_system.sopcinfo
2.soc_system_board_info.xml
3.hps_common_board_info.xml
Yet when I finished compile there is only one file generated:
soc_system.sopcinfo
The other two are not.
How can I get the other two?
My development environment is Quartus Prime 18.1 Lite, \
SOC EDS standard edition 18.1 \
Linux Altera_5.11.0.
reguards.
Hi Alex
Unfortunately we do not have an official how-to on editing device tree.
But I found an external link describing device tree syntax which I find helpful.
https://github.com/mykhani/device-tree-guide/blob/master/README.md
Jingyang, Teh
Hi
Sorry to inform you that the soc2dtb tool is no longer in used.
For the dtb there is no longer a tool to generate the dtb, it needs to be created manually.
Jingyang, Teh
Okey then
Thank you for the information.
reguards.
Hi Alex
Any update on this case?
Do you still need any more information?
Jingyang, Teh
I'm looking for the DTB tortour now yet it's a little hard to understand when should I update the DTB and how I write my own IP into the DTB.
Is there any official tortour for DTB customizing?
Thanks for help.
reguards.
Hi Alex
Jingyang, Teh
Thank you, I'll looking into it.
Hi
Since this thread been resolve, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
