5929 Discussions
How to program an I/O as a open drain on MAXII Micro Kit by using Quartus II?
Are there anyone knows how to program an I/O as a open drain on MAXII
Micro Kit by using Quartus II? I saw the MAXII device handbook. The MAXII
supports a function of open drain for the I/O. It can also support an internal
I/O clamp diode in I/O bank3. I, however, couldn't find any options on the
pin assignment of the Quartus II. I don't know what is wrong. Are there
anyone could tell me why? The Micro kit is a development kit from Terasic.
It has a CPLD EPM2210F324C3N. If you need any other information, tell me
please. Thank you!
Peter Chang:)
I've seen a post which uses a command as below in QSF.
set_instance_assignment -name AUTO_OPEN_DRAIN_PINS ON -to xxxxx
I've tried. I, however, couldn't find any difference on the Quartus II.
How can I know if the pins have been programmed as a open drain
output? Thanks.
Peter Chang
Most FPGA users define open drain function in HDL by assigning '0' respectively 'Z' output state, because it's a portable method working with any tool and CPLD vendor.
Hi FvM,
Thank you! It must be the easiest.
Peter :)
--- Quote End ---
