6367 Discussions
How to program and boot from EPCQ1024L for the Arria 10 SoC Development Kit after power up?
shavian2008
I am using the Arria 10 SoC Development Kit.  I could configure the FPGA with the SOF file and the programmer through the USB-BlasterII, but the content is lost once power off, and I need configure the FPGA many time.
Is there a way to write/programmed the on-board EPCQ1024L? so the FPGA is configured on power up automatically?
JohnT_Intel
You will need to change the SW4 switch to Active Serial Configuration mode first. Please follow table 22 of https://www.intel.com/content/www/us/en/programmable/documentation/iga1434736665480.html#iga1439496268303.
Then you will need to convert your sof file to jic file in order to configure the EPCQ flash content. You may refer to https://www.intel.com/content/www/us/en/programmable/documentation/mwh1410805299012.html for more information
shavian2008
 Thank you! The an370 is really helpful for my question.
 BRs
 shavian2008
JohnT_Intel
No problem. Glad to be able to help
