Oh.. no no.. You didn't understand my question. I don't want simulation. I actually want to test transceiver link onto the FPGA board. I have my bitstream onto the FPGA SoC board and I want to check the output of actual transceiver link onto the FPGA board. I know there is no way to observe the simulation of transceiver onto the putty. and I already have simulation results. But I have system (HPS+transceiver) onto my FPGA SoC board and I want to interact it with putty system.
Hie,
Signaltap tool is not a simulation tool. Its similar to a logic analyzer, except it can be accessed through JTAG connection.
The transceiver registers can be accessed through AVMM; hence using a HPS to AVMM bridge will allow you to access the transceiver registers. However, the rx_paralleldata is high speed data that is not available through registers. Hence, please check if accessing the rx_paralleldata through signaltap could help meet your requirement.
Please check more details on Signaltap in the following link:
https://www.youtube.com/watch?v=DCUhsezqydQ
Nathan
Oh. ok. Sorry I didn't know about that. Thanks a lot for the link. I shall check it out. Thanks a lot again.
