Hi Calvin
Thank you for the response, please find attached the info you need.
Jaco
Hi Jaco,
I am not able to see any attachment. Kindly please check and attach again.
Thank you.
If you are using the f version of the processor, you need a license for Nios. For the e (economy) version, you don't.
#iwork4intel
Problem Details
Error:
Internal Error: Sub-system: FIO, File: /quartus/ccl/fio/fio_path.cpp, Line: 85
Path name is too long -- must be shorter than 260 characters
Path (length 286): C:/Datasheets/Intel Altera/Cyclone 10/Cyclone 10 GX Dev Kit/examples/qts_fmc/qts_fmc/ip/xcvr_test_system/xcvr_test_system_data_pattern_generator_0/altera_avalon_data_pattern_generator_171/synth/xcvr_test_system_data_pattern_generator_0_altera_avalon_data_pattern_generator_171_7y4u42a.v
Stack Trace:
0x46ad: err_report_internal_error + 0x2d (CCL_ERR)
0xe139: fio_display_path_too_long_assert_message + 0x229 (CCL_FIO)
0xf0c0: FIO_PATH::flatten + 0xd00 (CCL_FIO)
0xabea: FIO_PATH::become_simplified + 0x4a (CCL_FIO)
0x52895: HDB_NAMESPACE::convert_to_relative_path + 0xdd (DB_HDB)
0x41af5: HDB_CAP_ASSIGNMENT_MAKER::IMPL::create_source_file_assignment + 0xc1 (DB_HDB)
0x420e2: HDB_CAP_ASSIGNMENT_MAKER::make + 0x132 (DB_HDB)
0x422c6: HDB_CAP_ASSIGNMENT_MAKER::make + 0x62 (DB_HDB)
0x47799: HDB_MODEL_BUILDER::process_assignment + 0x41 (DB_HDB)
0x479fd: HDB_MODEL_BUILDER::process_assignments + 0x145 (DB_HDB)
0x46a7e: HDB_CAP_ASSIGNMENT_MAKER::create_hdb_from_acf + 0x156 (DB_HDB)
0x70fe8: QHD_DESIGN_IMPL::load_flat_block + 0x118 (comp_qhd)
0x12e1f: qis_get_rtl_stage + 0x2bf (synth_qis)
0x12afa: qis_get_current_rtl_stage + 0xaa (synth_qis)
0x147f3: qis_analyze_files + 0x73 (synth_qis)
0x161e2: TclNRRunCallbacks + 0x62 (tcl86)
0x17a65: TclEvalEx + 0xa65 (tcl86)
0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
0xa5646: Tcl_EvalFile + 0x36 (tcl86)
0x13486: qexe_evaluate_tcl_script + 0x376 (comp_qexe)
0x12674: qexe_do_tcl + 0x334 (comp_qexe)
0x17635: qexe_run_tcl_option + 0x585 (comp_qexe)
0x25ff3: qcu_run_tcl_option + 0x1013 (comp_qcu)
0x1289: qsyn2_tcl_process_default_flow_option + 0xa9 (quartus_syn)
0x16f8a: qexe_run + 0x39a (comp_qexe)
0x17d31: qexe_standard_main + 0xc1 (comp_qexe)
0x3fa3: qsyn2_main + 0x123 (quartus_syn)
0x13778: msg_main_thread + 0x18 (CCL_MSG)
0x14f5e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x166e0: mem_thread_wrapper + 0x70 (ccl_mem)
0x12ce1: msg_exe_main + 0xa1 (CCL_MSG)
0x52ca: __tmainCRTStartup + 0x10e (quartus_syn)
0x14033: BaseThreadInitThunk + 0x13 (KERNEL32)
0x73690: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus_syn
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 17.1.0
Build: 240
Edition: Pro Edition
As the error states, your path is too long and you have spaces in it. Try shortening the path (put the project folder closer to the top-level of your hard drive) and avoiding spaces.
#iwork4intel
