5931 Discussions
I am writting the Verilog code and test bench for 4 bit shync up counter but I am not getting the desired output my code is below I should get cout as increased by 1 but I am not getting it when enable is high.
ASing173
sstrell
Your testbench is not toggling the clock, so nothing is going to happen.
#iwork4intel
ASing173
thanks I will check with that.....
ASing173
still I am facing the same problem tough my test bench clk toggling now....Screenshot 2020-04-07 at 9.07.58 AM.png
sstrell
You changed your always block so it is no longer clocked. Put it back to always @(posedge clk).
#iwork4intel
ASing173
ASing173
sstrell
I'm not familiar with this simulation tool, but perhaps you have to initialize or reset cout to a value instead of xxxx.
#iwork4intel
ASing173
its online tool edaplayground (icarus Verilog 0.10.0)
count depends on the inputs given i.e the reset and enable and I am giving both logic so according to that logic the output should be produced...
ASing173
