5777 Discussions
I cannot detect the jtag of my arria 10 fpga via blaster.
Zhilang_X_Intel
I cannot detect the jtag of my arria 10 fpga via blaster. I guess it is related to my wrong action of jtag chain debugger but I do not remember the detail action. Attach the detection result.
ShafiqY_Intel
Hi Liam,
Maybe you can refer to following KDB for workaround. Let me know is the issue haven't improve after try this workaround.
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/component/2019/why-does-an-intel-fpga-download-cable-or-an-intel-fpga-download-.html
Hope this will help.
Zhilang_X_Intel
Hi wolfgang,
I think it cannot solve my issue since I can detect another FPGA using my desktop and blaster. I think it is related to my wrong write to FPGA using JTAG chain debugger. Really need your help.
ShafiqY_Intel
Hi Liam,
Have you try update the newest driver for USB Blaster II?
If you want any further information about JTAG debugger, you can check the following video:
-https://www.youtube.com/watch?v=C_hh31u3Fdc
-https://www.youtube.com/watch?v=3xKB72SBOp4
Hope this will help
Zhilang_X_Intel
I have saw these two videos but it cannot solve my issue, the two videos only give an example to communicate with a good device but do not tell me how to confirm if my device is broken and how to fix it such as write some value to some registers.
ShafiqY_Intel
Hi Liam,
It has been a while since you have posted an update to this Forum. Do you have any update to me?
May I know the status of this issue?
Zhilang_X_Intel
Hi WolfGang,
I have not fixed this issue since I can not get useful information from your reply.
ShafiqY_Intel
Hi Liam,
Can you kindly try to reduce your TCK frequency to 12 or 6 MHz?
Below link is the command to change TCK frequency (on page 14= 2.8. Changing the TCK Frequency)
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_usb_blstr_ii_cable.pdf#page=14
Zhilang_X_Intel
Hi WolfGang,
I have tried both 12M and 6M but it cannot work. Do you have other suggestions? I am urgent on this issue.
ShafiqY_Intel
If you see the similar issue ! warning as above [open Nios II prompt Command, and execute command "jtagconfig".], it probably the windows issue.
Solution:
Open Quartus / Quartus Programmer as Run as Administrator. This should help you to detect the device.
