5784 Discussions
I cannot find the 5CSEMA5F31C6 in Quartus II
MDELE7
I have the DE1-SoC board, when I try to download the SRAM object file like in the instructions, the window of Select Device doesnt apear, I tried to add the device manually but I cant find the 5CSEMA5F31C6 device from the list.
Vicky1
If you are facing this difficulty while programming .sof file, check the below details from attached user manual,
  1. Refer the 3.1 Settings of FPGA Configuration Mode Especially SW10: MSEL[4:0]: 10010
  2. Ensure the device name(like 5CSEMA5F31C6 ) physically present on Kit/Board
  3. Connect the Intel download cable(USB Blaster cable),update drivers & then check "Hardware Setup" in programming
  4. Then refer the "Configure the FPGA in JTAG Mode" & follow the steps.
Vicky
Vicky1
Have you resolved the issue?
Should I consider that case to be closed?
Vicky
