5780 Discussions
I had coded RSA algorithm but i have some error(near end and end module and error in the if statement),i will attach my code, can you please check the code
RVava
module R1(c,m,p,q,i1,i2);
input [4:0]p;
input [5:0]q;input [7:0]m;
input[5:0] i1,i2;
output [19:0]c;
//reg [15:0]on;
wire [15:0]e;wire[15:0]d;wire [9:0]s;
integer k,l;
wire [9:0] j1,j2,j3,j4,j5,j6;
wire a1,a2,on;
always@(i1)
begin
k=i1;
l=i2;
if(i1[0]==1'b0 & i2[0]==1'b0)
begin
$display("not prime");
end
else
if((p%k==0)|(q%l==0))
$display("prime");
else
begin
end
end
assign s= p&q;
assign a1= p-1;
assign a2= q-1;
assign on = a1&a2;
module R1_enc(j5,j4,e);
input e;
output j5,j4;
always@(i1)
begin
//for (j=0;j<6;j=j+1)
//begin
assign j1=on % e;
assign j2=e % j1;
assign j3=j1 % j2;
assign j4=j2% j3;
assign j5=j3 % j4;
assign j6=j4 % j5;
//end
end
if(((j4%j5)==0)&((j3%j4)==1))
begin
//for(i=1;i<=n;i+1)
assign j1=on-(e&1010);
assign j2=e -(j1&1);
assign j3=j1-(j2&110);
assign j4=j2 -(j3&1);
end
else
begin
R1_enc(j5,j4,e);
end
//if((j3 -(j4&1))==1)&&((j4 -(j4&1))==0))
//if((j4 -(j4&1))==0)
begin
always@(e)
begin
if((j3-(j4&1))==1)
assign j4= j2-(j3&1);
if((j3-(j2&1))==1)
if((-1&j2)|(j3&10)==1)
assign j3= j1-(j2&110);
if(((-1&j2)|(j3&10))==1)
if((10&j1)|(-j2&1101)==1)
assign j2= e-(j1&1);
if((-1101&e)|(j1&1111)==1)
assign j1= on-(e&1010);
end
if(((-1101&e)|(j1&1111))==1)
if(((1111 & on)|(e & -10100011)|(e & on)|(-e & on))==1)
if(((1111 -e)& on)|(e & (on-10100011))==1)
if(((110011101 & e)|(on & -100110)) ==1)
end
always@ (e)
begin
if(((110011101 & e) % on )== 1)
begin
$display("110011101 is d");
$display("private key is (e,n)");
$display("public key is (d,n)");
end
endmodule
RichardTanSY_Intel
Not familiar with the RSA algorithm. Though, I saw there is a lot of 'if' statement stack together near the end of code, shouldn't we use 'else if' statement if there is more than one statement within an IF block. Correct me if I am wrong.
