5770 Discussions
I tried to run RTL sim in cadence tool (ncverilog) and found some encryption files in the libraries. Then, I got some messages as below about the key file. How can I fix it? Thanks.
sjhuo
The model encrypted file path: quartus/eda/sim_lib/mentor/twentynm_atoms_ncrypt.v
file: ../Model/FPGA/a10_model/twentynm_atoms_ncrypt.v
`pragma protect data_block encoding= (enctype="base64", line_length= 76, bytes= 25130288)
ncvlog: *F,DECERR (../Model/FPGA/a10_model/twentynm_atoms_ncrypt.v,37|90): Error while decrypting : unable to load key :(NCPROTECT_KEYDB environment variable not set).
ncverilog: *E,VLGERR: An error occurred during parsing. Review the log file for errors with the code *E and fix those identified problems to proceed. Exiting with code (status 2).
TOOL:  ncverilog  15.20-s035: Exiting on Apr 26, 2019 at 10:47:24 CST (total: 00:00:01)
KhaiChein_Y_Intel
You are running simulation in cadence tool but the simulation library is pointed to Mentor: quartus/eda/sim_lib/mentor/twentynm_atoms_ncrypt.v
You have to change to the simulation library to Cadence.
KhaiChein_Y_Intel
Hi, May I know if you have any updates? Thanks
sjhuo
​Hi, Sorry for my late reply.
I have solved this using cadence 's twentynm_atoms_ncrypt.v file.
I found that the cadence 's twentynm_atoms_ncrypt.v files. are only available in linux version quartus, not be available in windows version.
but this is not descripted in user-gudie. I suggest this information should be added in user-guide.
Thanks for your support !!
KhaiChein_Y_Intel
May I know the edition(Pro/Standard) and version of the Intel Quartus Prime software you are using?
sjhuo
Hi, I used Quartus Prime 16 build 211 Standard version.
Thanks!!
KhaiChein_Y_Intel
According to https://www.intel.com/content/www/us/en/programmable/documentation/gft1513990268888.html Table 1:Supported Simulators, Cadence simulator is supported in Linux 64-bit only.
