Library IEEE;
USE IEEE.Std_logic_1164.all;
entity RisingEdge_DFlipFlop_AsyncResetLow is
port(
Q : out std_logic;
Clk :in std_logic;
sync_reset: in std_logic;
D :in std_logic
end RisingEdge_DFlipFlop_AsyncResetLow;
architecture Behavioral of RisingEdge_DFlipFlop_AsyncResetLow is
begin
process(Clk,sync_reset)
begin
if(sync_reset='0') then
Q <= '0';
elsif(rising_edge(Clk)) then
Q <= D;
end if;
end process;
end Behavioral;
You have to be more clear on your requirements.
Question and implementation are different, in question you have mentioned "active high synchronous rest" and in code "AsyncResetLow". However your design is correct as per Asynchronous Reset Low.
For reference go to the template provided in quartus under edit->insert template->VHDL->Full designs->Shift Register.
Example:
process (clk, reset,enable_n )
begin
if (reset = '1') then --Active high Asynchronous rest
elsif (rising_edge(clk)) then
if (enable_n = '0') then --Active low synchronous enable
end if;
end if;
end process;
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand
