6369 Discussions
I used Quartus to generate the soc_system.sopcinfo file, and then use sopc2dts to build the corresponding soc_system.dtb. It seems that everything work fine except that the eth0 is down. Anyone have similar problem or any suggestion?
wchen50
FawazJ_Altera
May I know which FPGA device are you referring to? is it development kit or custom board?
thank you
wchen50
I am using DE0-Nano-Soc development board, which is using Cyclone V.
FawazJ_Altera
Hello.
Can you share with me the device tree?
Furthermore, have you tried the default GHRD image came with the board?
Thank you
