5778 Discussions
I would like to know if is possible to program the Si5351 clock generator on the Cyclone 10LP Evaluation Kit without using GUI
MCHOW8
I would like to be able to program the Max10 on board to configure the clock generator - is it possible to connect to and reconfigure the Max10? Also I've had
trouble finding the maximum acceptable clock rate for the Cyclone 10 LP in the specs...
AR_A_Intel
Hello Welcome to INTEL forum. We don’t have alternative way to program it. Please use GUI as it is available in the installation kit.
MCHOW8
Hi AAbd,
Thanks for the response. I would like to be able to power cycle the board and maintain the set frequency. Is there a way to do that with the GUI?
AR_A_Intel
Base on my understanding, NO, there are no option with GUI to able you to on the board and maintain the set frequency on the same time.
