Hello!
I wanted to evaluate the MAX10 Remote Upgrade over I2C (v17.1) with 10M50 and 10M08 Eval Boards, but I was not able to get the NIOS running and communicate over UART.
I could download all .pof and .sof images as described, but the core never responded. I noticed that downloading the NIOS firmware into QSPI flash takes much less time than described in the user guide.I also disabled the VTAP, but it did not work either.
Is there a special 10M50 Eval Board setup required?
Thank you in advance!
Hi!
Thank you for reply!
It looks like the Flash can not be programmed. Verify fails and after blank check it appears to be empty.
Do you have any ideas what could go wrong at this Eval Board?
@AFr12 Could solve your problem. I am also having same issue. My Flash verify fails after program/configure
