Hi, i am using the Arria 10 Transceiver Channels and currently doing a signal integrity analysis. I downloaded the IBIS-AMI files from the site and using it in Hyperlynx.
Based on the datasheet of Arria 10, the output termination resistor for TX can be set to OFF, 85 or 100. However in the IBIS model i do not see the OFF option to disable the termination resistor.
Anyone have any thoughts?
Thanks!
Hi Afiq,
Please correct me if I am wrong, this inquiry seems to similar to the IPS case 430202. For your information, I have responded to the IPS case for your reference.
Thank you.
